Message 1 of 5
Moving a BT socket
Redecorating so would like to move a DSL socket. Currently line comes through the external wall and sits directly over the hole that was made and would like to move it around 3 foot to an internal wall. Is this something you can do yourself or do I need a telecoms engineer ?
Have tried to post some photos but the files are too big even on the phones lowest settings.
4 REPLIES 4
Message 2 of 5
Re: Moving a BT socket
@Stanlee59
Who provides your phone and broadband connection?
Message 3 of 5
BT
Message 4 of 5
@Stanlee59 wrote:
BT
You could move it yourself if you know what you are doing, otherwise you would have to find someone local, which may be difficult during lockdown.
Message 5 of 5
Think I'll not chance it and look for someone to do it.
Ta.
