Message 1 of 2
Multiple dropouts have restarted again...
Hi,
Note on my previous thread from last year.
We are suffering from multiple dropouts with our internet again. Today we are on 12 (had 4 whilst typing this) alone and we have had an average of 3 dropouts per day since end of February/beginning March. This also coincides with when my neighbour across the road got added to the pole and a line fitted to their property. As per my recent thread here, an OP engineer fixed an issue left by a Kube engineer but did not look at the broadband problem. He left a contact number and has failed to responded to messages. I have checked for faults in my area but nothing shows. This feels like an exact repeat of last year and we ended up with 14 engineer visits before something finally 'fixed it'. There is no noise on the line. Each time the smart hub 2 flashes purple before going orange and then eventually back to blue. Will post hub stats below and most recent logs:
18:58:32, 13 Apr. CWMP: HDM socket closed successfully.
18:58:32, 13 Apr. CWMP: HTTP authentication success from pbthdm.x.x.x
18:58:32, 13 Apr. CWMP: HDM socket opened successfully.
18:58:32, 13 Apr. CWMP: session completed successfully
18:58:31, 13 Apr. CWMP: HDM socket opened successfully.
18:58:31, 13 Apr. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
18:58:30, 13 Apr. CWMP: Session start now, server: https://pbthdm.x.x.x, Event code: 4 VALUE CHANGE
18:58:30, 13 Apr. CWMP: Initializing transaction for event code 4 VALUE CHANGE
18:58:24, 13 Apr. SIP WAN UP
18:58:21, 13 Apr. NTP synchronization success
18:58:21, 13 Apr. NTP Server: ntp.homehub.btopenworld.com
18:58:09, 13 Apr. WAN Sensing Auto sensing Complete, interface selected
18:58:09, 13 Apr. WAN Sensing Auto sensing Running
18:58:08, 13 Apr. NTP synchronization start
18:58:08, 13 Apr. WAN Sensing Auto sensing Complete, interface selected
18:58:08, 13 Apr. WAN IPv6 Global unicast prefix / length: 2a00:23c5:b40b:ea00::/56
18:58:08, 13 Apr. WAN IPv6 Global unicast address allocated: 2a00:23c5:b40b:ea00::1/64
18:58:08, 13 Apr. WAN DHCPv6 events: BOUND
18:58:08, 13 Apr. WAN Sensing Auto sensing Running
18:58:08, 13 Apr. Success - secondary DNS servers
18:58:08, 13 Apr. Success - primary DNS servers
18:58:08, 13 Apr. WAN connection WAN2_INTERNET_PTM connected
18:58:08, 13 Apr. WAN DHCPv6 events: INIT
18:58:07, 13 Apr. PPP: IPCP up
18:58:07, 13 Apr. PPP IPCP Receive Configuration ACK
18:58:07, 13 Apr. PPP IPV6CP Receive Configuration ACK
18:58:07, 13 Apr. PPP IPCP Send Configuration Request
18:58:07, 13 Apr. PPP IPCP Receive Configuration NAK
18:58:07, 13 Apr. PPP IPCP Send Configuration ACK
18:58:07, 13 Apr. PPP IPCP Receive Configuration Request
18:58:07, 13 Apr. PPP IPV6CP Send Configuration ACK
18:58:07, 13 Apr. PPP IPV6CP Receive Configuration Request
18:58:07, 13 Apr. PPP IPV6CP Send Configuration Request
18:58:07, 13 Apr. PPP: CHAP authentication succeeded
18:58:07, 13 Apr. PPP CHAP Receive success : authentication successful
18:58:07, 13 Apr. PPP CHAP Receive Challenge
18:58:07, 13 Apr. PPP: LCP up
18:58:07, 13 Apr. PPP LCP Receive Configuration ACK
18:58:06, 13 Apr. PPP LCP Send Configuration ACK
18:58:06, 13 Apr. PPP LCP Receive Configuration Request
18:58:06, 13 Apr. PPP LCP Send Configuration Request
18:58:06, 13 Apr. PPP: Received PADS
18:58:06, 13 Apr. PPP: Sending PADR
18:58:06, 13 Apr. PPP: Received PADO
18:58:06, 13 Apr. PPP: Sending PADI
18:58:01, 13 Apr. PPP: Sending PADI
18:57:56, 13 Apr. PPP: Sending PADI
18:57:51, 13 Apr. PPP: Sending PADI
18:57:48, 13 Apr. DSL Link Up: Down Rate=52170kbps, Up Rate=7852kbps; SNR Margin Down=6.1dB, Up=6.2dB
18:57:46, 13 Apr. PPP: Sending PADI
18:57:41, 13 Apr. PPP: Starting PPP daemon
18:57:40, 13 Apr. WAN Auto-sensing detected port DSL WAN
18:57:20, 13 Apr. SIP WAN DOWN
18:57:17, 13 Apr. SIP WAN DOWN
18:57:17, 13 Apr. WAN Sensing Auto sensing Complete, interface selected
18:57:17, 13 Apr. WAN Sensing Auto sensing Running
18:57:15, 13 Apr. WAN Sensing Auto sensing Complete, interface selected
18:57:15, 13 Apr. WAN Sensing Auto sensing Running
18:57:15, 13 Apr. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
18:57:14, 13 Apr. PPP: Stopped PPP daemon(0,1,5)
18:57:14, 13 Apr. PPP LCP Send Termination Request (User request)
18:57:14, 13 Apr. PPP: IPCP down
18:57:14, 13 Apr. PPP: LCP down
18:57:14, 13 Apr. DSL Link Down: duration was 93 seconds
18:56:26, 13 Apr. SIP WAN UP
18:56:24, 13 Apr. NTP synchronization success
18:56:24, 13 Apr. NTP Server: ntp.homehub.btopenworld.com
18:56:10, 13 Apr. WAN Sensing Auto sensing Complete, interface selected
18:56:10, 13 Apr. WAN Sensing Auto sensing Running
18:56:09, 13 Apr. NTP synchronization start
18:56:09, 13 Apr. WAN Sensing Auto sensing Complete, interface selected
18:56:08, 13 Apr. WAN IPv6 Global unicast prefix / length: 2a00:23c5:b40b:ea00::/56
18:56:08, 13 Apr. WAN IPv6 Global unicast address allocated: 2a00:23c5:b40b:ea00::1/64
18:56:08, 13 Apr. WAN DHCPv6 events: BOUND
18:56:08, 13 Apr. WAN Sensing Auto sensing Running
18:56:08, 13 Apr. Success - secondary DNS servers
18:56:08, 13 Apr. Success - primary DNS servers
18:56:08, 13 Apr. WAN connection WAN2_INTERNET_PTM connected
18:56:08, 13 Apr. WAN DHCPv6 events: INIT
18:56:08, 13 Apr. PPP: IPCP up
18:56:08, 13 Apr. PPP IPCP Receive Configuration ACK
18:56:08, 13 Apr. PPP IPV6CP Receive Configuration ACK
18:56:08, 13 Apr. PPP IPCP Send Configuration Request
18:56:08, 13 Apr. PPP IPCP Receive Configuration NAK
18:56:07, 13 Apr. PPP IPCP Send Configuration ACK
18:56:07, 13 Apr. PPP IPCP Receive Configuration Request
18:56:07, 13 Apr. PPP IPV6CP Send Configuration ACK
18:56:07, 13 Apr. PPP IPV6CP Receive Configuration Request
18:56:07, 13 Apr. PPP IPV6CP Send Configuration Request
18:56:07, 13 Apr. PPP IPCP Send Configuration Request
18:56:07, 13 Apr. PPP: CHAP authentication succeeded
18:56:07, 13 Apr. PPP CHAP Receive success : authentication successful
18:56:07, 13 Apr. PPP CHAP Receive Challenge
18:56:07, 13 Apr. PPP: LCP up
18:56:07, 13 Apr. PPP LCP Receive Configuration ACK
18:56:07, 13 Apr. PPP LCP Send Configuration ACK
18:56:07, 13 Apr. PPP LCP Receive Configuration Request
18:56:07, 13 Apr. PPP LCP Send Configuration Request
18:56:07, 13 Apr. PPP: Received PADS
18:56:07, 13 Apr. PPP: Sending PADR
18:56:07, 13 Apr. PPP: Received PADO
18:56:07, 13 Apr. PPP: Sending PADI
18:56:01, 13 Apr. PPP: Sending PADI
18:55:56, 13 Apr. PPP: Sending PADI
18:55:51, 13 Apr. PPP: Sending PADI
18:55:49, 13 Apr. DSL Link Up: Down Rate=52340kbps, Up Rate=5761kbps; SNR Margin Down=6.1dB, Up=6.0dB
18:55:46, 13 Apr. PPP: Sending PADI
18:55:41, 13 Apr. PPP: Starting PPP daemon
18:55:41, 13 Apr. WAN Auto-sensing detected port DSL WAN
18:55:20, 13 Apr. SIP WAN DOWN
18:55:17, 13 Apr. SIP WAN DOWN
18:55:17, 13 Apr. WAN Sensing Auto sensing Complete, interface selected
18:55:17, 13 Apr. WAN Sensing Auto sensing Running
18:55:15, 13 Apr. WAN Sensing Auto sensing Complete, interface selected
18:55:15, 13 Apr. WAN Sensing Auto sensing Running
18:55:15, 13 Apr. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
18:55:14, 13 Apr. PPP: Stopped PPP daemon(0,1,5)
18:55:14, 13 Apr. PPP LCP Send Termination Request (User request)
18:55:14, 13 Apr. PPP: IPCP down
18:55:14, 13 Apr. PPP: LCP down
18:55:14, 13 Apr. DSL Link Down: duration was 1082 seconds
18:48:16, 13 Apr. ARP [add] br0(wl1) 192.168.1.66 ac:37:43:cc:9e:26
18:48:15, 13 Apr. ARP [del] br0 192.168.1.66 ac:37:43:cc:9e:26
18:41:15, 13 Apr. ARP [add] br0(wl1) 192.168.1.244 08:7c:39:ba:5a:2f
18:40:50, 13 Apr. DHCP device Connected: 192.168.1.244, 08:7c:39:ba:5a:2f, unknown
18:40:50, 13 Apr. LAN [ADD] ARP 192.168.1.244 with 08:7c:39:ba:5a:2f from br0(wl1)
18:40:50, 13 Apr. 5G Client disassociate from 08:7c:39:ba:5a:2f (IP=192.168.1.244) RSSI=0, Rate=0Mbps
18:40:48, 13 Apr. WHW INFO A station (Smart Hub 2)IF[2.4G](A4:CE:DA:40:52:91):STA(08:7C:39:BA:5A:2F)(Legacy Device) join WHW infrastructure
18:40:37, 13 Apr. DHCP device Connected: 192.168.1.244, 08:7c:39:ba:5a:2f, unknown
18:40:36, 13 Apr. LAN [ADD] ARP 192.168.1.244 with 08:7c:39:ba:5a:2f from br0(wl0)
18:40:36, 13 Apr. ARP [add] br0(wl0) 192.168.1.244 08:7c:39:ba:5a:2f
18:40:36, 13 Apr. DHCP device Disconnected: 192.168.1.244, 08:7c:39:ba:5a:2f, unknown
18:40:36, 13 Apr. LAN [DEL] ARP 192.168.1.244 with 08:7c:39:ba:5a:2f from br0
18:40:33, 13 Apr. 2.4G Client disassociate from 08:7c:39:ba:5a:2f (IP=192.168.1.244) RSSI=0, Rate=0Mbps
18:40:32, 13 Apr. WHW INFO A station STA(08:7C:39:BA:5A:2F) leave WHW infrastructure
18:40:32, 13 Apr. ARP [del] br0 192.168.1.244 08:7c:39:ba:5a:2f
18:40:32, 13 Apr. 2.4G client Mac: 08:7C:39:BA:5A:2F Deauthentications (Reason:Disassociated due to inactivity )
18:39:43, 13 Apr. ARP [add] br0(wl0) 192.168.1.244 08:7c:39:ba:5a:2f
18:39:35, 13 Apr. DHCP device Connected: 192.168.1.244, 08:7c:39:ba:5a:2f, unknown
18:39:35, 13 Apr. LAN [ADD] ARP 192.168.1.244 with 08:7c:39:ba:5a:2f from br0(wl0)
18:39:33, 13 Apr. WHW INFO A station (Smart Hub 2)IF[5G](A4:CE:DA:40:52:90):STA(08:7C:39:BA:5A:2F)(Legacy Device) join WHW infrastructure
18:38:54, 13 Apr. admin login success from 192.168.1.101
18:38:30, 13 Apr. CWMP: HDM socket closed successfully.
18:38:30, 13 Apr. CWMP: HTTP authentication success from pbthdm.x.x.x
18:38:29, 13 Apr. CWMP: HDM socket opened successfully.
18:38:29, 13 Apr. CWMP: session completed successfully
18:38:29, 13 Apr. CWMP: HDM socket closed successfully.
18:38:29, 13 Apr. CWMP: HTTP authentication success from pbthdm.x.x.x
18:38:28, 13 Apr. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
18:38:28, 13 Apr. CWMP: Session start now, server: https://pbthdm.x.x.x, Event code: 4 VALUE CHANGE
18:38:28, 13 Apr. admin timeout from 192.168.1.101
18:38:28, 13 Apr. CWMP: Initializing transaction for event code 4 VALUE CHANGE
18:38:01, 13 Apr. SIP WAN UP
18:37:58, 13 Apr. NTP synchronization success
18:37:58, 13 Apr. NTP Server: ntp.homehub.btopenworld.com
18:37:44, 13 Apr. WAN Sensing Auto sensing Complete, interface selected
18:37:44, 13 Apr. WAN Sensing Auto sensing Running
18:37:43, 13 Apr. WAN IPv6 Global unicast prefix / length: 2a00:23c5:b40b:ea00::/56
18:37:43, 13 Apr. WAN IPv6 Global unicast address allocated: 2a00:23c5:b40b:ea00::1/64
18:37:43, 13 Apr. WAN DHCPv6 events: BOUND
18:37:43, 13 Apr. NTP synchronization start
18:37:43, 13 Apr. WAN Sensing Auto sensing Complete, interface selected
18:37:42, 13 Apr. WAN Sensing Auto sensing Running
18:37:42, 13 Apr. Success - secondary DNS servers
18:37:42, 13 Apr. Success - primary DNS servers
18:37:42, 13 Apr. WAN connection WAN2_INTERNET_PTM connected
18:37:42, 13 Apr. WAN DHCPv6 events: INIT
18:37:42, 13 Apr. PPP: IPCP up
18:37:42, 13 Apr. PPP IPCP Receive Configuration ACK
18:37:42, 13 Apr. PPP IPV6CP Receive Configuration ACK
18:37:42, 13 Apr. PPP IPCP Send Configuration Request
18:37:42, 13 Apr. PPP IPCP Receive Configuration NAK
18:37:42, 13 Apr. PPP IPCP Send Configuration ACK
18:37:42, 13 Apr. PPP IPCP Receive Configuration Request
18:37:42, 13 Apr. PPP IPV6CP Send Configuration ACK
18:37:41, 13 Apr. PPP IPV6CP Receive Configuration Request
18:37:41, 13 Apr. PPP IPV6CP Send Configuration Request
18:37:41, 13 Apr. PPP IPCP Send Configuration Request
18:37:41, 13 Apr. PPP: CHAP authentication succeeded
18:37:41, 13 Apr. PPP CHAP Receive success : authentication successful
18:37:41, 13 Apr. PPP CHAP Receive Challenge
18:37:41, 13 Apr. PPP: LCP up
18:37:41, 13 Apr. PPP LCP Receive Configuration ACK
18:37:41, 13 Apr. PPP LCP Send Configuration ACK
18:37:41, 13 Apr. PPP LCP Receive Configuration Request
18:37:41, 13 Apr. PPP LCP Send Configuration Request
18:37:38, 13 Apr. PPP: Received PADS
18:37:38, 13 Apr. PPP: Sending PADR
18:37:38, 13 Apr. PPP: Received PADO
18:37:38, 13 Apr. PPP: Sending PADI
18:37:33, 13 Apr. PPP: Sending PADI
18:37:28, 13 Apr. PPP: Sending PADI
18:37:22, 13 Apr. PPP: Sending PADI
18:37:20, 13 Apr. DSL Link Up: Down Rate=52196kbps, Up Rate=7629kbps; SNR Margin Down=6.1dB, Up=6.2dB
18:37:17, 13 Apr. PPP: Sending PADI
18:37:12, 13 Apr. PPP: Starting PPP daemon
18:37:12, 13 Apr. WAN Auto-sensing detected port DSL WAN
18:36:45, 13 Apr. PPP: Stopped PPP daemon(0,1,5)
18:36:45, 13 Apr. DSL Link Down: duration was 21 seconds
18:36:45, 13 Apr. PPP: Sending PADI
18:36:40, 13 Apr. PPP: Sending PADI
18:36:35, 13 Apr. PPP: Sending PADI
18:36:32, 13 Apr. DSL Link Up: Down Rate=52503kbps, Up Rate=2261kbps; SNR Margin Down=6.3dB, Up=0.0dB
18:36:30, 13 Apr. PPP: Sending PADI
18:36:25, 13 Apr. PPP: Starting PPP daemon
18:36:24, 13 Apr. WAN Auto-sensing detected port DSL WAN
18:35:58, 13 Apr. PPP: Stopped PPP daemon(0,1,5)
18:35:58, 13 Apr. DSL Link Down: duration was 21 seconds
18:35:58, 13 Apr. PPP: Sending PADI
18:35:53, 13 Apr. PPP: Sending PADI
18:35:48, 13 Apr. PPP: Sending PADI
18:35:45, 13 Apr. DSL Link Up: Down Rate=52348kbps, Up Rate=2405kbps; SNR Margin Down=6.3dB, Up=0.0dB
18:35:43, 13 Apr. PPP: Sending PADI
18:35:38, 13 Apr. PPP: Starting PPP daemon
18:35:37, 13 Apr. WAN Auto-sensing detected port DSL WAN
18:35:17, 13 Apr. SIP WAN DOWN
18:35:14, 13 Apr. SIP WAN DOWN
18:35:14, 13 Apr. WAN Sensing Auto sensing Complete, interface selected
18:35:14, 13 Apr. WAN Sensing Auto sensing Running
18:35:12, 13 Apr. WAN Sensing Auto sensing Complete, interface selected
18:35:12, 13 Apr. WAN Sensing Auto sensing Running
18:35:12, 13 Apr. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
18:35:11, 13 Apr. PPP: Stopped PPP daemon(0,1,5)
18:35:11, 13 Apr. PPP LCP Send Termination Request (User request)
18:35:11, 13 Apr. PPP: IPCP down
18:35:11, 13 Apr. PPP: LCP down
18:35:11, 13 Apr. DSL Link Down: duration was 1013 seconds
18:23:29, 13 Apr. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
18:21:26, 13 Apr. ARP [add] br0(wl1) 192.168.1.66 ac:37:43:cc:9e:26
18:21:24, 13 Apr. ARP [del] br0 192.168.1.66 ac:37:43:cc:9e:26
18:19:30, 13 Apr. CWMP: HDM socket closed successfully.
18:19:29, 13 Apr. CWMP: HTTP authentication success from pbthdm.x.x.x
18:19:29, 13 Apr. CWMP: HDM socket opened successfully.
18:19:29, 13 Apr. CWMP: session completed successfully
18:19:29, 13 Apr. CWMP: HDM socket closed successfully.
18:19:28, 13 Apr. CWMP: HDM socket opened successfully.
18:19:28, 13 Apr. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
18:19:28, 13 Apr. CWMP: Session start now, server: https://pbthdm.x.x.x, Event code: 4 VALUE CHANGE
18:19:28, 13 Apr. CWMP: Initializing transaction for event code 4 VALUE CHANGE
As shown with 5 dropouts and I can provide more logs with similar readings for the past day alone. Speeds are fine but kind of useless with the constant drop outs.
1 REPLY 1
Message 2 of 2
Re: Multiple dropouts have restarted again...
Hi @zoni23 Thanks for posting, I'm so sorry to see you're getting drops again and really hope it's not a reoccurrence of the previous issues. I've reopened the private message you sent and one of the community moderators will be happy to look into this for you and will be in touch.
Neil
