Message 11 of 13
Re: My ip is hidden - I am blocked from hosting provider
Thanks, Les-Gibson. I'll try a neighbour - at a proper distance of course
Message 12 of 13
@Kwarr
have you tried turning hub off and waiting 10/15 minutes then restart and get a different IP address for the hub to see if that makes any difference
Message 13 of 13
Re: My ip is hidden - I am blocked from hosting provider.
I restarted the router yesterday and that didn't fix it. Switching off, waiting 20mins and switching on again WORKED
Thank you to all who have helped me
