Message 11 of 13
Re: My recipients are being misdirected when they click on 'reply'
@JohnC2wrote:
Hi @gordon8, welcome to the forum, and thanks for posting. Sorry that replies to your email are going elsewhere. We'll be happy to help you get this fixed. I've sent you a Private Message so you can get in touch with the team for help.
cheers
John
Can you explain why "Reply-to" is not available to be deleted by end users via webmail? Also explain why it is not available at all via webmail.
This clearly leads on to there being many in a potential similar situation - which needs to be investigated and the users who have this set in webmail informed about it.
Why don't you do proper fault finding, rather than single cases?
Message 12 of 13
Many thanks for your help! Issues seem to be resolved now! Awesome!
Best Regards
Gordon
Message 13 of 13
Best Regards
Gordon
Thanks for popping back to say it's fixed.
Were you told what the problem was, and how it was cleared?
