Message 1 of 4
Neighbours can get fibre, except me
Hi,
Currently stuck in a situation that people around me can enjoy fibre but not me. Really reluctant to sign into a contract only slightly cheaper than fibre but way slower. Can someone explain this to me whether I can see the light of the end of the tunnel sooner? TIA!
3 REPLIES 3
Message 2 of 4
Re: Neighbours can get fibre, except me
@madlilies
Are you a BT Retail customer, if so, then use your phone number and not your address?
If you are not a BT Retail customer, then you need to ask on your own ISPs forum, as its Openreach not BT Retail that provide the fibre network.
If you are intending to place your order with BT Retail, then you need to get a phone number first, by placing an order for a phone line. Once that is working, then the Openreach database will be updated, and you should see what your options are.
If this matches your postcode, then fibre is not available.
Marylebone
Cabinet P39   Openreach fibre not available            W1U 7AJ
Message 3 of 4
same applies to P29
Cabinet P29   Openreach fibre not available            W1U 6EQ
Message 4 of 4
