Message 1 of 4
Network uptime reset
Had a lot of issues with my fibre broadband regarding dropouts and had loads of engineers round to try and solve the problem, we finally had one engineer that came and found the ports in the green cab were loose and fixed them, since then had 0 dropouts and went nearly 21 days connected.
I then decided to upgrade to fibre 2 again as my line could finally handle itself, Fibre 2 went live early hours Monday morning and was fine all day, I woke to find my DSL uptime still going strong but my network uptime showing 6 hours 19 minutes which means something happened early hours of this morning but I’m not sure what. Can anyone help with this, hopefully it was something minimal like BT checking network as for the first 10 days the speeds can fluctuate and whatnot.
Please help, I don’t want all this hassle with dropping connections again
3 REPLIES 3
Message 2 of 4
Re: Network uptime reset
Message 3 of 4
 Ah ha you’re possibly right
Message 4 of 4
There have been a number of similar reports like this. Not sure how long the planned work is going on for, but I would expect it to stop soon.
