Message 1 of 5
New Customer
Evening all.
I am a Virgin customer atm but I am getting BT Fibre installed next week.
Happy to move away from DOCSIS and Intel Puma issues.
I plan to use my existing Netgear R8000 as a router directly connected to the ONT so I don't need to reconfigure my LAN.
I have some stuff which I need help, I need an IPv4 address. Do BT supply IPv6 addresses now?
I need an IPv4 address because I use dynamic DNS to update my A records.
Does having an IPv6 address affect gaming?
4 REPLIES 4
Message 2 of 5
Re: New Customer
You will get both IPv4 and IPv6 addresses, both dynamic.
The PPPoE details for your router are the generic username [email protected] and password BT
Message 3 of 5
Re: New Customer
Thank you, do you know of any DNS providers which support Dynamic AAAA record updates?
Message 4 of 5
Re: New Customer
Possibly.
http://www.noip.com/support/knowledgebase/what-is-an-ipv6-or-aaaa-record/
Message 5 of 5
Re: New Customer
Loving my full fibre 900, here is a BQM I have setup for my Full Fibre connection
 https://www.thinkbroadband.com/broadband/monitoring/quality/share/6049bbe1d039a4166eaee5f467a777cc98...
It looks much better than when I was using Virgin Media.
I am currently using my own router (Nighthawk R8000), would I get better latency with a router with more cores?
