Message 11 of 22
Re: New FTTP install question
You could always try using the existing cable if it has 8 wires.
Message 12 of 22
Great shout. I'll have a look to see if its twisted pair behind the back boxes.
Message 13 of 22
Result.
Full twisted pair sitting in the master box with only blue and blue/white connected.
It's weird what makes you happy during these mental times! 😄
Message 14 of 22
Message 15 of 22
Appreciate all your info today. You've been a massive help.
Final question. (It might be stupid so apologies)
Is the easiest option just to terminate the twisted pair cable with an RJ45 connector and plug it in to the ONT or should i get a backbox installed with an RJ45 face plate?
I'm assuming that it wouldn't be as simple as fixing all the twisted pairs up to the correct connections on current Openreach main box and replacing secondary RJ11 face plate with an RJ45 one to give a direct connection?
Message 16 of 22
Once you get FTTP your current Master socket will no longer be used for broadband.
Personally, I would fit a backbox with an RJ45 face plate adjacent to the current master socket and then just use a patch lead to connect the ONT to the socket as I doubt the cable would be long enough to reach the ONT if you simply terminated it in a plug. Then simply replace the extension RJ11 faceplate with an RJ45 faceplate.
Message 17 of 22
Will it be used at all?
I'm very limited for space so would struggle to get another back box in on top of the FTTP stuff.
If I need to I'll make it work though.
There's a good 15-20 cm of cable tucked away in the master box so might get lucky and be able just to terminate it.
Message 18 of 22
You probably need to wait and see where the ONT can be located to see if it will reach. Are you getting digital voice with the FTTP or retaining your copper landline for telephony? If the copper landline cable is going to be redundant, you could just swap the master socket for an RJ45 faceplate and leave the incoming cable coiled up behind.
Message 19 of 22
Have went for digital voice so copper landline should be redundant which should work out perfectly!
Thanks again for the help. 👍
Message 20 of 22
As the master socket will be redundant just replace the faceplate with an RJ45 and connect the extension wires to it, no need for a secondary back box. You'll also need an RJ45 socket at the other end.
