Message 1 of 6
No incoming calls
I've discovered that since the switchover I'm no longer receiving incoming calls.  I can dial out and I do have a dialling tone.  My phone is a BT6500 with additional handset.  Can anyone advise?
5 REPLIES 5
Message 2 of 6
Re: No incoming calls
by switchover do you mean to Digital Voice?   if so did you get a free DV phone?  is your 6500 connected to the socket on the back of the SH2 or are you using a DV adapter?
what happens if you call home from mobile?
Message 3 of 6
Phone is plugged into Openreach socket Mk4.
Calls from mobile to landline sound as ringing but no sound from home phone.
Message 4 of 6
so what did you mean by switchover?
have you tried a different phone to check problem still exists?  if it does then phone CS 150 or 0800800150 from mobile and report fault
Message 5 of 6
Thanks, I'll try a different phone see what result I get.
Message 6 of 6
@GillRangel
Did you note @imjolly asked you whether you have tried plugging the phone into the SH2, assuming you are now set-up for digital phones.
See an earlier topic with an illustration:  https://community.bt.com/t5/BT-Devices/Smart-Hub-2/td-p/2102282
Further, if your are now digital, you should have received a DEC phone.
