Message 1 of 6
No signal all afternoon
Is there a problem with the mobile network in SK13 area?  I've had no signal all afternoon.  Incoming calls go straight to answerphone, outgoing calls say number not registered😏
5 REPLIES 5
Message 2 of 6
Re: No signal all afternoon
Just check using Google.
https://istheservicedown.co.uk/status/bt-british-telecom/2648405-glossop-derbyshire-england-united-k...
Message 3 of 6
Thanks, looked at this and shows no issues.  On Facebook local group people saying Vodafone, EE been down as well.
Message 4 of 6
I'm sure the issue is long-since resolved, but https://coverage.ee.co.uk/coverage/ee would be a much better place to check than a third party site.
Message 5 of 6
Thank you
Message 6 of 6
Angela, BT use the EE network for mobile phones.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
