Message 1 of 1
No way to access Cloud dashboard
Newbie to cloud. I've installed BT Cloud and the BT Cloud icon has put itself onto the top system bar ok and when looking at the "getting started with BT Cloud" pages the instructions for a MAC say;
You can adjust your settings in the BT Cloud dashboard. Once BT Cloud is installed, you can access the dashboard by clicking the BT Cloud icon in the top system bar, then clicking Show Dashboard.
ONLY PROBLEM IS  There isn't a "Show Dashboard" option.
(there is) All files synced, Open BT Cloud sync, Launch Web, Preferences & 'the 3 vertical dots'
Any help appreciated, thanks
