Message 1 of 12
Noise Margin/Speed
Hi
Total newb here... short explanation: I've had a 5 month long saga which I think I'm emerging from. Everything from drop wire replacements, lift and shifts, etc. etc.
Recently it was discovered that after a lift & shift, there was a failure to reset card profiling, which an engineer said was probably causing latest drops/errors, & since that visit, & card reset, things have been stable and great. Though, my speeds have not returned to what I think they should be... which is basically full whack. I'm on an 80/20 circuit, with a brand new line to cabinet [which is performing almost perfectly according to engineers' tests] which is a maximum of 50 yards away from my house. I think the fact I haven't returned to what I was getting prior to all these problems might be something to do with a noise margin setting - though I'm not sure. I was previously able to sync 80/20 & get a throughout speed of 74/18 - but I think recent engineer visit has cracked it. Cos I'm now not getting the daily drops I was. However, I seem to be stuck on 74/16 sync speed - which is below my previous. I know this is a "first world" problem, cos even that is pretty good - but with the work I do, as a documentary editor, I need as much juice as I can get out of it.
Any one have an idea as to whether the noise margin is the thing that's causing it not to rise back to normal? Is it higher than it should be? Can it be lowered? - any help really gratefully received - ta - Dom
Here are my stats:
Firmware version:v0.26.04.04227-BT
Firmware updated:Fri May 14 00:01:16 2021
Board version:R01
GUI version:1.74 12_11_2020
DSL uptime:4 days,05 Hours23 Mins24 Secs
Data rate:16.996 Mbps / 74 Mbps
Maximum data rate:25.075 Mbps / 87.522 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:10.8 / 9.3
Line attenuation:6.8 / 12.6
Signal attenuation:6.8 / 14.6
11 REPLIES 11
Message 2 of 12
Re: Noise Margin/Speed
Those look OK. Nothing to be done there.
Message 3 of 12
oh... I was reading that they should be around 6db? Have I got this wrong? also... given the maximum data rate is 25.075 Mbps / 87.469 - I'm not sure why I haven't returned to 80/20 - maybe this will happen over time after my recent stability issues? How long does this usually take?
ta
D
Message 4 of 12
You will never have a 6dB noise margin due to the max attainable. If you now have a stable line then it can take up to 3 weeks to return speeds. Or longer.
Message 5 of 12
ok thanks for your help. I don't really understand the relationship between noise margin/max attainable. But, to be fair, I don't really understand noise margins in general. I just read somewhere about it being set to 6db. But to be honest, it's difficult to navigate the forums with such little technical knowledge - they can often be contradictory & impenetrable. But as long as my noise margin seems normal, then fine. Thanks
Message 6 of 12
The target noise margin is 6dB but if the line is capable of more then the noise ratio changes.
A way to explain it is this. If they line is capable of a higher rate then the hub doesn't have to shout as loud to be heard, therefore the noise margin is different to a hub that does. 6dB is the margin where noise equals the shouting. With a higher max data rate then the hub doesn't have to shout as much to be heard so the noise margin gets further apart, ie, higher than 6B
Message 7 of 12
ah... ok..... that's clear. Great. So hopefully, as my line seems more stable now than it has been in months... I'll return to 80/20 sync once again in the next few weeks - providing the stability continues
Message 8 of 12
Correct. Hopefully so.
Message 9 of 12
I had this myself at my old flat, I found after a DLM profile reset due to a few errors on my life my noise margin was at 8db, but I left it on for a few weeks and it dropped down to 4db eventually. Just leave the router on and let it do its thing. That's what I found anyway. Noise margin works differently on FTTC than it did on ADSL connections.
Message 10 of 12
Great, thanks for reply... - It's been a long running saga, with many twists and turns - but I think this profile reset has resolved errors/drops - so gonna let it do its thing, and hope it'll return back to my previous sync speed of 80/20 - fingers crossed
