Message 1 of 23
Decling speeds on orginal line and New line upload speed only 10mbps
I've been a customer for years and had a stable connection. However the speed over the years has declined 72Mbps to 60mbps and still dropping while upload stayed at 20Mbps
This into a vigor 130.
Anyway after virgin ignored and failed to correct a fault I decided to have a 2nd broadband connection.
The engineer came and instead of putting a 2nd line in used the existing line.
The speed came back at 60mbps and 14mbps on the BT hub and when I switched to the Vigor 130.
A week later the 2nd line had dropped to 10mbs and has stayed there.
Recently the original feed has started having more disconnections I used to go up 400 hours plus. I've noticed the speed has now dropped again to 53Mbps.
The line test is quiet.
Since I'm using 130's I can produce much in the way of stats except the snr 6db which seems a bit low.
I can plug the BT Hub back in if need be however do I need to contact BT about the declining speeds? Or wait until it goes down below 47Mbps?
22 REPLIES 22
Message 2 of 23
Re: Decling speeds on orginal line and New line upload speed only 10mbps
The snr 6 is fine however it does drop down to five which I should have posted.
Message 3 of 23
have you turned of smart setup
Turn Off smart setup
enter your phone number and post results remember delete number
Message 4 of 23
Hi I'm not using the BT Hub so no smart connect. Had to reduce the size of the image as the original file was too large.
Message 5 of 23
as you can see from checker the estimated range for your line in 68/52mb with handback at 47mb and from checker you connection speed on 31/5 was 60.6mb so well within expected range
Message 6 of 23
What about upload speeds on the broadband line which are 9999Mbps
I guess I'll have to wait for it to drop below 47Mbps.
However is steadily declining.
Message 7 of 23
Can you tell me of any ISP who guarantees upload speeds? Everything is centred on download. I think it's wrong too.
Message 8 of 23
Actually virgin will do if it gets low enough. That's if you can get them interested in the first place.
Message 9 of 23
Upload speed now down to 9000 on the 2nd line.
Message 10 of 23
Spoke to BT and they could see a lot of errors on the line so raised a fault.
He was also surprised they didn't actually supply a proper 2nd line rather than using the present line.
