Message 1 of 7
ORDI Fault
Ive been in touch with BT Local Business in relation to an ORDI fault (Error OR5492),  however i have not received a response or a solution.
Is anyone able to help resolve this?
Many Thanks
6 REPLIES 6
Message 2 of 7
Re: ORDI Fault
If you are a BT Buisness user you will need to post on the BT Business Forum.
Message 3 of 7
Re: ORDI Fault
please advise where i can find the BT Business Forum
Message 4 of 7
Re: ORDI Fault
Google BT Business forum!
Message 5 of 7
Re: ORDI Fault
https://business.forums.bt.com/
Message 6 of 7
Re: ORDI Fault
It would have been more helpful if you provided a link
Message 7 of 7
Re: ORDI Fault
Yes but then you would never learn!
