Message 1 of 6
Whos using Fibre 2 with geforce now?
Anyone able to use geforce now with getting around 70mbps ? Any packet loss?
Cheers
5 REPLIES 5
Message 2 of 6
Re: Whos using Fibre 2 with geforce now?
Most likely there are many. Why do you have a problem?
Message 3 of 6
I use GeForce Now daily to play Fortnite Save the World. Before anyone say, no I don’t play Battle Royale I’m well past it. My connection is 80/20 throughput 74/19. No issues whatsoever with the wife and 4 kids in the house.
Message 4 of 6
yes but im with sky. I feel its sky that is the problem.
Im on the network alone, connected via ethernet. I also changed my router for better standard. Constant packet loss. If I use a VPN with TCP protocol it helps somewhat but not 100%. Im only .3km from the cabinet so I pull around 70mbps. So annoying!
Message 5 of 6
If you are with Sky you would be better posting on their forum where you would get answers relevant to a Sky user.
Message 6 of 6
This is a customer to customer forum for BT Retail customers. If you're having issues with GeForce Now via Sky broadband, ask on their forums.
