Message 1 of 11
Openreach installation
Hi all.
I have finally been able to order fibre to the prem.
I go "live" in a fews days time.
I'm due to receive my brand new smart hub 2 any day now.
So my question is, when should I expect Openreach to come to the premises to do whatever they need to do?
Will BT let me know or Openreach? Do they contact me as I assume they'll have to enter the property?
I'm currently on a copper line so there is no fibre line in the property.
Any help or advice would be greatly appreciated.
Cheers
10 REPLIES 10
Message 3 of 11
Re: Openreach installation
You'll have been given the date/time when the internal installation should happen at the time of ordering plus on the order confirmatiom. Openreach should attend to do external work only before then which you don't need to be in for
Message 4 of 11
Thanks for the reply.
Oh.... thats not a good start. I've double checked my order etc and nothing. Just states that my "kit" will be delivered and that I go "live" in a few days.
Any suggestions what I should do next.....please....
Message 5 of 11
Phone FTTP TEAM 08005874787
Message 6 of 11
@garybs29  Depends if it is a 1 or 2 stage install. Most installs now are 1 stage meaning everything is done at the same time, both inside and out.
Message 7 of 11
Thank you....
Yet another call to BT.
Wish me luck
Message 8 of 11
@pippincp i know but i was going by the fact they've mentiined there's a copper line already so likely to be a 2 stage
Message 9 of 11
@garybs29Please educate me, I'd be more than happy to know why. CBT fibre installs which Openreach are now using are 1 stage installs.
Message 10 of 11
@pippincp The 1st link posted earlier by @gg30340 mentions 2 stage installations still, if that's changed BT need to update their info then
