Message 1 of 3
Parental controls suspension
Hi,
I am trying to set up parental controls but want to suspend them between 8pm and 1am.  How can I do this.  When I try and set it up I just get a message saying the start time has to be earlier than the end time.  So it seems suspending them from say, 7pm to 11pm is fine, but what about from 8pm to 1am?
2 REPLIES 2
Message 2 of 3
Re: Parental controls suspension
Hi @Broomfield15,
Thank you for posting and welcome to the Community.
When setting up the Parental Controls suspension, the suspension period has to be on the same day. If you were looking for the suspension period to start at 20:00 the maximum time it could run would be up until 00:00.
I hope that helps?
Thanks,
Paddy
Message 3 of 3
Thanks, so I think you are saying it can't be done.
