Message 1 of 2
Passwords
I am unable to use password override  'invalid password override section'. please make sure the light is blinking.
The light is blinking however whatever password i put in, it just wont accept it
I gave up with the above and decided too hard reset the router.   I put a pin in the reset hole and pushed and can hear a click for 3 seconds however nothing happens with the router. ive tried it several times.
All i want to do is turn off 5ghz so that my new 2.5ghz device connects
1 REPLY 1
Message 2 of 2
Re: Passwords
When you do factory reset and push pin in back you need to hold for 20/30 seconds until the hub lights flash otherwise it does not reset
