Message 1 of 3
Router and ONT
Just recently had FTTH and wondered if I can connect a router straight into the ONT? I'm looking at buying 3rd party router and wondered if anyone else has done this? The ONT is a modem/multiplexer from what I know so no need for the bt hub 2?
If anyone knows it would be much appreciated, thanks.
2 REPLIES 2
Message 2 of 3
Re: Router and ONT
Of course you can, countless folks do just that. You just need to enter the generic PPPoE login details on the third party router which are Username [email protected] and password BT.
Just bear in mind that if you have Digital Voice, it will not work with a third party router, it requires the Smart Hub2 which acts as a DECT base station.
Message 3 of 3
Re: Router and ONT
Oh brilliant that's good I only have 1 socket for power so this will be perfect, thanks for the reply 😀
