Message 1 of 15
Poor speed after install
I've just switched to sky from BT.
I'm on fibre 2  expected 50Mb - 73Mb and guarantee of 45Mb. When I was on Sky I was just on 50mb.
I went live 3 days ago and initial speed tests were 42mb but now its down to 32.
Is this drop expected. Is it still likely to go back up and settle in the expected range? I know its expected to fluctuate but wasn't expecting the lower range.
I switched from sky to get better faster broadband.
Thanks for advice.
14 REPLIES 14
Message 2 of 15
Re: Poor speed after install
in order for the forum members to help please can you post the stats from your router HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 15
Hi, quiet line test seemed quiet!!
Product code:Smart Hub 2
Serial number:+091298+2019023307
Firmware version:v0.17.01.12312-BT
Firmware updated:Wed Aug 5 00:39:25 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:2 days,06 Hours13 Mins52 Secs
Data rate:20 Mbps / 44.44 Mbps
Maximum data rate:20.296 Mbps / 53.670 Mbps
Noise margin:6.0 / 6.3
Line attenuation:8.3 / 14.1
Signal attenuation:8.1 / 16.5
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:16.9 GB Uploaded / 82.4 GB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-99AJXP
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name:BT-99AJXP
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:18:82:8C:0B:14:E2
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 4 of 15
Message 5 of 15
Thanks for the advice. Statistics and screen shots attached. Hope this is helpful for advice.
Message 6 of 15
have you tried using the test socket with a filter to see if that improves your connection speed  test socket is behind the front plate of the master socket
if you connect to test socket please repost hub stats
Message 7 of 15
Its exactly the same line. So should get the same speeds.  What speeds did you get quoted ?
Message 8 of 15
@madhatter2426  1st post, 2nd sentence.
@LUFCCharlie  Which exchange and cab?
Message 9 of 15
Hi Holmfirth exchange, CAB unsure  how do I know or is it on the CAB?
Message 10 of 15
