Message 1 of 1
Poor system
I had a problem with phones not being able to connect to my BT hub - 2 android phones, both have connected to the hub for months if not years, yet suddenly they can't connect "access denied". iPad seems unaffected. I looked for answers here. I found user emnov74 with a similar problem, clicked the 'solution' link and got a post that seemed unrelated to the question originally asked. Not at all impressed. I was then asked if I would take a survey for the site, I responded yes. I filled out survey, only to find when submitting it, I had to be logged in to do so! Why offer surveys to non-logged in users, if they can't respond! Even less impressed. Luckily I poked around in the BT hub admin and reset the 2.4 & 5GHz channels - after that the phones could login OK. So problem solved (for now anyway), but no thanks to this site. Now registered with this site to post this bad review.
Tags (3)
