Message 1 of 5
Port Forwarding / DDNS Question
Hey All,
I have a home network which has got a CCTV and House Alarm system running through my Draytek Router. I want to move onto the Home Hub 2 as I've now got 900MB Fibre.
The two devices internal have a fixed IP and I have set the range on the Home Hub to be the same range i.e. 192.168.0.X
I can reach the CCTV and Alarm internally no issues.
I have set up a NO IP DDNS Service and set a host to the external IP and then gone and set up the port forward rules for each port I want to use (as per my previous config - TCP and UDP rules as needed).
Unfort I can't get a hit on the devices using the new hostname I set up through NO IP.
Clearly a port forward or rule / config issue.
Anyone got any tips at all on any other setting required and does anyone know if there is a limit on the amount of rules you can set up for port forwarding?
Any advice appreciated.
Mike
4 REPLIES 4
Message 2 of 5
Re: Port Forwarding / DDNS Question
@michaeljpower73
This thread that I've been posting into today might help you.
Message 3 of 5
Thanks Tim - I will have a look through it now.
Anonymous
Not applicable
Message 4 of 5
Check your public IP address then log into your DDNS account and make sure the IP address on your account matches.
Message 5 of 5
Tried all that unfort and they match perfect 🙂
