Message 11 of 24
Re: Premium Whole Home Wi-Fi SGAB208224 Release now live
Any upgrade firmware for complete wifi eg hybrid connect lights won't turn off
Message 12 of 24
@dephead2004
This thread is to do with the white whole home retail discs, and not the BT black complete wifi discs, please start a new thread.
You do have an existing thread here https://community.bt.com/t5/BT-Devices/Complete-Home-WiFi-Hybrid-Connect-Lights-amp-Connection-statu...
Message 13 of 24
All true but as you can see that was posted in June and no reply to date. Not even a no!
And not the first time that silence is golden
Message 14 of 24
Anyone still having problems with the disc rebooting (mainly the master disc).
When I used the early adopter it was more stable but now on the final version it's now rebooting a couple of times per day.
I have backed up, factory reset and restored my settings.  I will need to try changing out the master disc with one of the secondary ones but surely this is moving the issue around and not sure if I can restore to a secondary if changing to master?
Message 15 of 24
Hi @bigmick777
Please take a look here: https://community.bt.com/t5/BT-Devices/Premium-Whole-Home-Wi-Fi-amp-Whole-Home-Wi-Fi-6-SGAB-C208228/...
There is a fix for the random primary disc reboot in this early adopter release.
Dan-O
Message 16 of 24
Thanks - it's just shown up as an available update - will give it a try.
Message 17 of 24
Can i ask what your uptime is showing?
does the uptime reset or show x days still?
Message 18 of 24
Up time resets when master disc reboots so not been going past a day up time.  Rebooted this morning so uptime currently 4hrs.
Message 19 of 24
Thanks as i read your post i checked mine, mine showing 6 days up however as these are used for my IOT network i may not have noticed any reboots so i wanted to check that the disc uptime was indeed being resetting in gui after any reboot.
@ Dan-o or BT
Fixed occasional primary disc random reboots
System stability improvements: Is this worth updating if i have no rebooting issues? what other Stability improvements have been applied?
Message 20 of 24
Hi @foz
I would suggest updating to this release anyway due to the stability fixes - to make sure you don't have any issues with leaving your setup running for a long period of time.
SGAB/C208224 are available to rollback if you did need to return to this version.
To avoid confusion - it would be better to discuss the Early Adopter release SGAB/C208228 on the dedicated thread:
Dan-O
