Message 1 of 3
Pro box
Does anyone know when the WiFi option will be enabled on the pro box?
If you are using power line adapters I noticed that it looks like you can plug into the adapter, so for instance if I were using the adapter for say the pro box would I plug the adapter into the wall socket and then plug the pro box into the adapter, if not can you please explain how it would work. Thanks.
2 REPLIES 2
Message 2 of 3
Re: Pro box
Hi @J62
two links that may help with your second question
first the user guide for the Pro Box
https://www.bt.com/content/dam/bt/help/f1-box-/BT-TV-Box-Pro-Wired-User-Guide.pdf
and about  the power line adapters
https://www.bt.com/help/tv/getting-set-up/setting-up-bt-tv/bt-mini-connectors-for-bt-tv
Message 3 of 3
Re: Pro box
Thank you, that is helpful.
