Anonymous
Not applicable
Message 1 of 2
Problem with BT TV app
Hello,
I have the following problem with the BT TV app when I set a recording using the app the recording does not show the recording on the box.
can you give the the email address for the BT TV app so that I can email them with the problem
thanks
Matthew
1 REPLY 1
Message 2 of 2
Re: Problem with BT TV app
You can email [email protected] Matthew, but it'll just come to me anyway ... so I'll just reply here instead. 🙂
Select the My TV tab in the app, then Recordings List, then the History tab at the top - it should show the status of any recording requests you've sent from the app.  If they're all stuck in a "Pending" state then that would suggest your box ID has been reset.  You'll need to pair the app with the box again - select My TV, then Settings, then Unpair.  Then pair it again.
