Message 1 of 4
Problems combining two 3 packs of whole home discs
Hello,
I have bought 2 x 3 packs of whole home discs.
I have set them up by setting up the first 3 pack as per the instructions, then when I add discs from the second pack I use “add a new disc”, connecting each of the 3 additional discs via Ethernet in turn, factory resetting it, adding it to the network.
Everything seems to work fine and I have a full network of 6 discs, then at some point, after a few hours, the three new discs disconnect themselves from the network, go red and need to be re-added. They don’t start broadcasting their own SSID, they just don’t connect properly.
All the discs are on the latest firmware.
I have read other posts on here which suggest I do the steps which I have already taken.  Did anyone have this problem and manage to solve it?
3 REPLIES 3
Message 2 of 4
Re: Problems combining two 3 packs of whole home discs
Message 3 of 4
Hello!
Thanks for the link. That is the process I followed yet at some time after set up, the additional discs stop working.
Message 4 of 4
@AndyNW wrote:
Hello!
You may get a reply from @Darren_B
