Message 1 of 7
Problems with playback of recordings
Hi
We are having problems with playback on our recordings on our Youview box.  Many programmes appear pixelated and skip forward a few seconds constantly. If we rewind we can see the missing bit so it is not as if the programme did not record properly. It just won't play properly. Any ideas as to what might be the problem> Thanks.
6 REPLIES 6
Message 2 of 7
Re: Problems with playback of recordings
Hi @Flipperty
Can you  give the model of Youview  box and examples of the  actual channel s that you are experiencing the problems on .
Using the Youview remote .. help button followed by i(nfo) button will give the model number  and software version
Message 3 of 7
Hi thanks for replying
The box is model Humax DTRT4000
Software CDS/32.53.0
Channels vary from BBC4, Yesterday, ITV 3 for example.
Message 4 of 7
@Flipperty  thanks  for the details.
When roughly did the problem first start ?
When you rewind and are able to see the skipped section how far back are you rewinding, are you rewinding back to before it started pixelating and skiping. (Ie does it consistently  pixelate and skip at same point  or does it sometimes  play through without  hitch).
Message 5 of 7
No when you rewind it plays through without a hitch - suggesting the recording is OK but playback isn't. Not sure what would make playback do this. More skipping in playback than pixelating although both do occur.
Message 6 of 7
Wonder whether  it is some form of  interference but why only on playback is a mystery. Or possibly some cumulative error count.
Might be worth doing a maintenance  node reset 2 or 4 preserving recordings on the box.
Message 7 of 7
Thank you for taking the time to reply - I will give that a go.
