Message 1 of 9
Ps5 no wifi ?
Ps5 no wifi?
8 REPLIES 8
Message 2 of 9
Re: Ps5 no wifi ?
Mine has WiFi so it definitely has it.
Message 3 of 9
Re: Ps5 no wifi ?
It works.but it stutters when l play
Message 4 of 9
Re: Ps5 no wifi ?
Has but cannot play the game
Message 5 of 9
Re: Ps5 no wifi ?
Go to the network settings on the PS5 and run a connection test...
Message 6 of 9
Re: Ps5 no wifi ?
Out of interest is it all games or just one particular game?
You need to run through basic checks ie checking the PS5 is within an acceptable range from the router, what traffic is being used, plotting the property out using something like iperf where you can see how throughput is effected by distance via environment.
You also need to see if it’s connected to 5Ghz or 2.4Ghz.
The PS5 uses an AX1800 chipset and is 2x2 and will have best performance using WiFi 6 based router.
Message 7 of 9
Re: Ps5 no wifi ?
in every game as play.l get stuck.l have the router at the bottom and the ps5 at the top
Message 8 of 9
Re: Ps5 no wifi ?
@Artur88 have you checked the PS5 connection speeds as I suggested?
Message 9 of 9
Re: Ps5 no wifi ?
Yes ok thank
