Message 1 of 3
Public IP not forwarding ports
I have been using dynamic DNS to faciltate remote access to my BT service, without issue.  However, recently (sometime since lockdown started), I have found that both SSH (on non-standard port) and VPN have both stopped working.  My modem is unchanged.   I have spend some time trying to find the problem on my side, and found nothing.  I am now suspecting this is a BT issue.
Is there a change in the BT infrastructure causing this?
In one tracert, I found that there were 3 private IP hops before reaching a public IP.  (But this is not currently the case).
Basically I would like to know if I should be contacting BT, or continue to try find the fault on my side.
Thanks,
Theo
2 REPLIES 2
Message 2 of 3
Re: Public IP not forwarding ports
Some Dynamic DNS services have moved to HTTPs which the home hub doesn't support. You could try  a different free Dynamic DNS service to see if that works.
Message 3 of 3
I have checked the Dynamic DNS.  That is not the problem.
I'm using IPV4 address.
