Message 1 of 7
Query about disconnecting Modem
I need to disconnect my Openreach modem, possibly for a few days as we will have a plasterer in and he will need to plaster behind this, is there any problem with this? Do I need to inform BT? I read somewhere about disconnecting in the Router console so it was an obvious disconnect but wanted to make sure this was the case?
6 REPLIES 6
Message 2 of 7
Re: Query about disconnecting Modem
No, you don't need to inform anybody. Just don't keep connecting and disconnecting or DLM will see it as a line fault.
Message 3 of 7
Do you have FTTP and the modem is the openreach ONT?
Message 4 of 7
Yes to both of queries. Was told by an engineer it couldn’t come off the wall after it was installed in February.
Message 5 of 7
I assumed you were talking about an Openreach DSL modem rather than an ONT. Unless you are familiar with optical connectors, I recommend that you don't disconnect the ONT. You do so entirely at your own risk.
Message 6 of 7
I hope it’s not an ONT, Mud Slingers and SC Optical Connectors don’t get on. 😆
Message 7 of 7
If you don't have any dust caps for the optical connector then it's probably best to disconnect the power and ethernet cable only from the ONT, pop it in a plastic bag and seal it by tying a cable tie/string around the end of the bag sealing it against the still connected fibre cable as the last thing you want is any plaster/dust/paint getting on the fibre connector. Be careful about how much strain is put on the cable when the ONT is off the wall.
