Message 11 of 22
Re: Random Mac addresses on wifi, am I being hacked?
Good morning guys,
Is this an attack. The first part was at 9am this morning and second part was at 7am this morning.
9:00:002  DoS(UDP Loopback): IN=ppp1 OUT= MAC= src=184.105.139.113 DST=86.172.255.252 LEN=29 TOS=0x00 PREC=0x00 TTL=52 ID=13870 DF PROTO=UDP SPT=35571 DPT=19 LEN=9 MARK=0x8000000
DoS(Port Scanning): IN=ppp1 OUT= MAC= src=89.248.165.97 DST=86.172.255.252 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=17658 PROTO=TCP SPT=54679 DPT=2714 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
07:00:02, 18 May.
DoS(Port Scanning): IN=ppp1 OUT= MAC= src=89.248.165.97 DST=86.172.255.252 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=55354 PROTO=TCP SPT=54679 DPT=2796 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
07:00:02, 18 May.
DoS(Port Scanning): IN=ppp1 OUT= MAC= src=89.248.165.97 DST=86.172.255.252 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=41341 PROTO=TCP SPT=54679 DPT=2503 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
07:00:02, 18 May.
DoS(Port Scanning): IN=ppp1 OUT= MAC= src=89.248.165.97 DST=86.172.255.252 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=46140 PROTO=TCP SPT=54679 DPT=2794 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
07:00:02, 18 May.
DoS(Port Scanning): IN=ppp1 OUT= MAC= src=89.248.165.97 DST=86.172.255.252 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=64292 PROTO=TCP SPT=54679 DPT=2933 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
07:00:02, 18 May.
DoS(Port Scanning): IN=ppp1 OUT= MAC= src=89.248.165.97 DST=86.172.255.252 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=54061 PROTO=TCP SPT=54679 DPT=2850 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
07:00:02, 18 May.
DoS(Port Scanning): IN=ppp1 OUT= MAC= src=89.248.165.97 DST=86.172.255.252 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=38464 PROTO=TCP SPT=54679 DPT=2983 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
07:00:02, 18 May.
DoS(Port Scanning): IN=ppp1 OUT= MAC= src=89.248.165.97 DST=86.172.255.252 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=61433 PROTO=TCP SPT=54679 DPT=2811 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Message 12 of 22
Is this anything to worry about?
Good afternoon guys,
07:00:02, 18 May.
07:00:02, 18 May.
07:00:02, 18 May.
07:00:02, 18 May.
07:00:02, 18 May.
07:00:02, 18 May.
07:00:02, 18 May.
Message 13 of 22
Just your firewall doing its job.
Please don't post the same question in more than one place, it just causes total confusion for replies. I have merged your posts.
Message 14 of 22
Thank you for your reply. I did another post as I didn't think no one would read the old thread.
Message 15 of 22
Re: Is this anything to worry about?
Yes this is definitely just your firewall doing it’s bit.
I’d try not to post your public IP address online though, that MIGHT lead to someone attempting hack, just a tip 😁
Message 16 of 22
The IP address ending 252 is yours, the others both lead to sites which claim to be legitimate sites for gathering information on the internet.
One claims to be working with law enforcement agencies for improving security on the internet, the other just states that it gathers information such as open ports but doesn't say why
Message 17 of 22
Thanks guys. This has just happened again and theres like two pages of it in my log plus this -
2.4G client Mac:  Deauthentications (Reason:Deauthenticated because sending station is leaving (or has left) IBSS or ESS)
Which is my roku box and there's also 2 pages of this.
Message 18 of 22
Virtually every broadband user will have the same thing in their logs, it is a fact of life when connected to the internet, That is why you have a firewall.
The other, is just mobile device disconnecting.
Message 19 of 22
Thank you. So I guess there is nothing to worry about.
What things would you look for if there was a hack?
The whole police improving security thing sounded a little strange.
Message 20 of 22
Its extremely unlikely that you will be 'hacked' by a brute force attack on your home router. Any sort of hacking problems  you encounter will either be due to a hack of a commercial site exposing your details or by clicking on dodgy links in phishing emails.
