Message 1 of 4
Random dropping internet for some devices
I have 6 devices hooked up to my older BT router. Just about every day, and more than once per day, one or more of my devices will be disconnected - random devices - I cannot re-establish connection without rebooting my router and sometimes more than 1 reboot. Everything worked fine until about a month ago. I don't understand what is causing the problem and it's very very frustrating.
3 REPLIES 3
Message 2 of 4
Re: Random dropping internet for some devices
you need to try and avoid constant rebooting of the hub as that will have a detrimental affect on your connection speed.  is it just wifi devices or also devices connected with ethernet?
have you tried 1 factory reset of hub by pressing recessed button on back and holding 20/30 secs until lights flash?
Message 3 of 4
Thanks - I've tried the factory reset  and all  looks good - at the moment. It's a home hub 5 router. I'll wait and see if the problem recurs.
Message 4 of 4
All my devices are wifi
