Message 1 of 4
Random high ping times within my network
Hello.
Like a lot of people I'm working from home. I've hard-wired everything, event so, and on teams / zoom I have random freezes and zoom will sometimes tell me helpfully that my internet connection is unstable.
The various ping / tracert calls are all telling me the issue is between my computer and the BT Home Hub 5 (Type A)
Software version 4.7.5.1.83.8.264
Last updated 05/03/19(192.168.1.254)
To convince myself it's a hub issue, I've plugged my machine directly into the hub and disconnected *everything* else, and the results can be seem below. To reiterate: This is the ping down a single cat6 ethernet cable direct into the HUB, with nothing else connected (wireless disabled). At the time of writing, the HUB has been up for 9 days.
C:\Users\g1nge>ping -t 192.168.1.254
Pinging 192.168.1.254 with 32 bytes of data:
Reply from 192.168.1.254: bytes=32 time=1ms TTL=64
Reply from 192.168.1.254: bytes=32 time=1312ms TTL=64
Reply from 192.168.1.254: bytes=32 time=5ms TTL=64
Reply from 192.168.1.254: bytes=32 time=1764ms TTL=64
Reply from 192.168.1.254: bytes=32 time=4ms TTL=64
Reply from 192.168.1.254: bytes=32 time=1622ms TTL=64
Reply from 192.168.1.254: bytes=32 time=8ms TTL=64
The ping lags are typically up to 2000ms with no packet loss.
The results are unaffected by restarting or resetting the HUB, the pinging machine type (same issue on the wife's Mac, my linux server, son's laptop) - so I think the issue has to be with the HUB itself?
The only other possibility I can think of is I'm the subject of the lamest Denial of Service attack ever, which randomly denies my service for about 2000ms every 30 seconds or so 😛
Any bright ideas? At this point I'm about to throw my hands up and spend the £70 on a newer shinier router (VR400 seems to get good reviews despite being a bit long in the tooth) to see if that will make a difference.
3 REPLIES 3
Message 2 of 4
Re: Random high ping times within my network
Hi @g1ngerrevolution and thanks for posting.
Sorry you're having problems with the connection. have you noticed if the hub lights change when this happens? Is there any noise on your line?
Cheers
David
Message 3 of 4
Really similar issues here.
Spikes not generally noticeable while streaming but very noticeable in gaming. In Zoom etc, I get the same issues - unstable connection.
Message 4 of 4
I did a quiet line test, all seemed good.
No lights on the HUB that I've noticed changing.
