Message 1 of 4
Re: Blank Screens
How do I perform a factory reset? Blue screen showing on one receiver, but no details.
3 REPLIES 3
Message 2 of 4
Re: Blank Screens
Hi @colinboast Welcome to the community and thanks for posting. What issues are you having with your BT TV?
Have you checked all the cables are connected properly? Check out this link for instructions on how to Factory reset your BT TV box
Neil
Message 3 of 4
Re: Blank Screens
I'm referring to my BT telephones ref: BT 6600 Trio  which suffer fom a disappearing screen leaving just a blue blank area. Others on this site have suffered the same fault, but nobody can solve the problem. Even BT maintaining a silence over this and nowhere do they offer a response. I refuse to use the premium rate call line to them!
Message 4 of 4
Re: Blank Screens
Hi @colinboast  and thanks for posting.
I moved your thread to the devices board as yo0u'd posted on the BTTV board (which is why @NeilO replied with that information). Can you try the following and let me know if it helps?
  1. Select Menu, scroll to display settings and press Select.
  2. Press S to highlight Reset and press Select.
  3. H/set settings is highlighted, press Select or press calls to highlight base settings and then press select.
  4. Reset <handset or base> settings back to default? is displayed, select Yes.
  5. Resetting <handset or base> settings is displayed while the reset takes place. Once finished, handset or base settings reset back to default is displayed.
Cheers
David
