Message 1 of 3
Re: Capped upload @448k
Hi DavidM, also have a line that appears to be capped at 448k that it'd be great to get help moving to ADSL2. Info I think that's needed below. Able to help me pls? thanks vm. RTRT
Hmm my paste of the checker output was auto edited - try again with ADSL2 only...
New paste with ADSL2 info only
WBC ADSL 2+WBC ADSL2+ Annex M
Up to 4--2.5 to 6.5AvailableAvailable--
Up to 4Up to 0.52.5 to 6.5AvailableAvailable--
Original paste below
Telephone Number 020 XXXX XXXX on Exchange WALWORTH
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed Rate
--------Available--
2----AvailableAvailable--
Observed Speeds ADSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
6.94
0.45
2020-02-29
Other Offerings Availability DateADSL Multicast
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
U
2 REPLIES 2
Message 2 of 3
I moved your post from the 4 year old thread to start your own thread
can you post stats from your router
the formatting of dslchecker makes it difficult to read
Message 3 of 3
Here's the info from the broadband status page IMJ -hopefully that helps? If not then happy to copy across whatever else needed.
Connection status:
Connection type:
Broadband (DSL)
Downstream sync speed:
6.72 Mbps
Upstream sync speed:
448.00 kbps
Network uptime:
5 Days, 8 Hours 17 Minutes
Smart Setup:
Broadband IP address:
5.80.XXX.YYY
Default gateway:
172.16.10.8
Primary DNS:
81.139.57.100
Secondary DNS:
81.139.56.100
System uptime:
5 Days, 8 Hours 19 Minutes
Serial number:
XXXXXX
Firmware version:
SG4B1B0092BE
Firmware updated:
05-Mar-2020
