Message 41 of 90
Re: Download speed has been reduced
Hi
ill check this
thanks
ian
Message 42 of 90
As I’m nearly 24hrs at 35Mb Down I’m resisting fiddling till it changes as this is the best it’s been for ages, if it holds up I’ll replace the Devolo with BT set or another set that doesn’t seem to radiate interference from its power supply
Message 43 of 90
So today it’s dropped again, it did it yesterday morning too, now down to 15Mb down and 7Mb up, will do quiet line today
Message 44 of 90
2hrs later it’s dropped again but back up to 33Mbs down and 5 up
Message 45 of 90
are you still in test socket with filter with only 1 device connected?
Message 46 of 90
Yes only the hub connected , but not the test socket, behind the faceplate
Message 47 of 90
Have you managed to do quiet line line test from the test socket yet?
Message 48 of 90
Hi
no as I thought it was best to let the vdsl settle down
Message 49 of 90
Done quiet line from test socket, can hear slight hiss on our cordless phone,
Message 50 of 90
So having done quiet line and re clipped on faceplate, speed up to 32MBs again
