Message 2 of 7
Re: New Digital Voice home phone service on BT
Just took delivery of my Digital Voice handsets {essential} yesterday. I already have Smart Hub 2.
Registered the first handset and all up and running but won`t let me register the second, stuck on Press
the WPS button...worked for the 1st handset !
6 REPLIES 6
Message 1 of 7
Re: Digital Phone connectivity to Hub
I have received 2 handsets for digital voice, registered the first but unable to register the 2nd handset .
Any one else got this problem?
Message 3 of 7
I have moved your posts to start a new thread where you are more likely to get help rather than lost in the noise of other threads that have a different problem.
Message 4 of 7
try going to hub manager then selecting phone number then reset base  the try registering phone from same place with 'register handset'
Message 5 of 7
OK
Message 6 of 7
Thanks, the solution was indeed the hub...just needed a reboot. I switched off, waited a few seconds and switched on again. Tried to register the second handset again and success. Many thanks for directing me to the hub.
Message 7 of 7
Thanks, Imjolly, the hub was the solution...just needed a reboot!
Tags (1)
