Message 1 of 4
Receiving calls from people saying I called them, but I haven’t!
I have recently received calls from people saying they are returning my call. I haven’t called them, but they say my number appears as a missed call. Is this a scam and should I be concerned?
3 REPLIES 3
Message 2 of 4
Re: Receiving calls from people saying I called them, but I haven’t!
Message 3 of 4
It's probably scammers "spoofing" your number, so it shows when they call potential victims.
Cheers
Ted
Message 4 of 4
Just in case your line has been crossed with someone else, dial 17070 and the AVR should read out your number , if it matches what you expect , then as already explained, scammers can make their calls look like any number they want , but that doesn’t affect you as far as billing  ,just the hassle of answering calls from people , that return the scammer call , if 17070 reads out a number you don’t recognise then your line is crossed with someone else , and obviously calls intended for that number would come through to you, if that’s the case you need to report the fault.
