Message 21 of 24
Re: Receiving calls from people saying I called them, but I haven’t!
How come the start of the number it called is the same as mine though? It’s weird. Literally the first 7 numbers
Message 22 of 24
That is because the scammers think it is more likely people will answer a call from an exchange they recognise than something random.  They change the digits to match the circumstances.
Used to happen to me a lot until I installed a call blocker, these are mostly pretty good at squashing the nonsense.
Message 23 of 24
When it happened to you was the first 6-7 digits the same numbers in the same order as yours then? It was only the last 3 numbers that was different to mine.
Message 24 of 24
Hi, for any potential call spoofing problems (where you receive calls from people saying you've called, but you haven't), please reach out to our Nuisance Calls Bureau (NCB) team on 0800411422. The team are available Mon - Fri 8:30 am - 5 pm.
They’ll be able to investigate the problem for you.
Please also see our nuisance or scam calls page at - https://www.bt.com/help/security/how-can-i-stop-nuisance-or-scam-calls-
