Message 1 of 2
Recombine 2.4 and 5Ghz bands
I have a bt smart hub 6, and I managed to split the 2.4 and 5ghz bands by changing the name of the 5ghz band. After I changed it, I wanted to revert what I had just done, but whenever I try and change the name back, it always forcefully adds a "-5" on the end. I have tried looking for a separate bands button, however I cannot find it. Any help would be appreciated.
Thanks,
1 REPLY 1
Message 2 of 2
Re: Recombine 2.4 and 5Ghz bands
The easiest way is just to factory reset by pressing the recessed button on the back and holding 20/30 secs until lights flash.  Remember turn off smart setup after reset
