Message 11 of 14
Re: Recordings cut off short
Thanks @DarrenDev for looking into the problem. I have deleted my recording as only half of match there. Is the problem only on uhd/HDR channel 465, or also on ultimate channel 433, and would it affect HD channel 430. Man City v Chelsea is the lunchtime game on BT on 15 Jan so think I will record on 430/433 and 465 and hope one channel will give me the whole match.
Message 12 of 14
What is you download speed? Record on 433 and 465 at same time will require almost 60Mbps download on their own.
Fibre 2 Unlimited using EE Smart Hub 2 with EE TV Box Pro (UHD/HDR) in IP mode.
Message 13 of 14
Thanks for the reply @ozsat I was being more tha a little facetious. The point I was trying to make was that channel 465 is the only BT offering in uhd/HDR and I have been unable to record the whole 90 minutes of football. Using the HD channel is no substitute.
Message 14 of 14
Could it be that the available stream is dropping below 30Mpbs which interupts and then kills it though?
I do know that if anything interupts the recording it fails to restart.
