Message 1 of 6
Remote Access / Port Forwarding
Hi
I'm working from home and running a company server on my local network.
My co-worker (in another location) needs access to the server.
Can anyone explain how to set up port-forwarding (if that's what I need to do) to allow my co-worker to access the server on my local network?
thanks
5 REPLIES 5
Message 2 of 6
Re: Remote Access / Port Forwarding
@kungfuslippers
Who provides your broadband connection?
Message 3 of 6
What router do you have?
Message 4 of 6
It's a  BT HUB 6
Message 5 of 6
Message 6 of 6
Is the company server setup for remote access? if not you can't and if it is do you have remote admin access?
This sounds more like a question for your IT security bods
