Message 1 of 7
Removal of right to exit
Hello,
I've raised a fault this morning after having issues with our fibre speeds dropping to 15mb. I completed the report a fault process and I have noticed that it now says the following at the bottom.
'We’ve had to remove your right to exit your contract without penalty, as we’ve not been able to monitor your speed or get any required information from you.'
At no point has it asked me for any more information and it must have appeared within minutes of the fault being registered. any ideas why it would say this or what I can do myself to sort out my speed issues. Our stay fast guarantee, guaranteed us minimum speeds of 45mb.
Many thanks
6 REPLIES 6
Message 2 of 7
Re: Removal of right to exit
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 7
Thank you for the quick reply. My son also told me that he saw the light on the hub go yellow yesterday afternoon.
Technical log:
Product code:Smart Hub 2
Serial number:+091298+1832013411
Firmware version:v0.21.03.07094-BT
Firmware updated:Sat Oct 17 18:05:37 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:0 days,20 Hours47 Mins35 Secs
Data rate:9.105 Mbps / 18.367 Mbps
Maximum data rate:10.012 Mbps / 32.221 Mbps
Noise margin:8.6 / 14.1
Line attenuation:9.2 / 17.9
Signal attenuation:9.2 / 21.3
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:490.4 MB Uploaded  / 7.8 GB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-W5A2MS
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name:BT-W5A2MS
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:4C:1B:86:76:26:96
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
Line test: All quiet
Message 4 of 7
did you try quiet line test?
are you having problems with connection dropping or maybe trying resets to get improved speed or maybe a combination of both
have you tried using the test socket with a filter to see if that improves your connection by eliminating your internal wiring as causing a problem   if you connect to test socket then please repost hub stats
Message 5 of 7
Hi imjolly
I did the quiet line test and it was quiet.
Internet speeds were around 47mb and then since the hub light went yellow speeds have dropped to around 15mb.  I will try the test socket and post the results.
Many thanks
Message 6 of 7
Test socket results:
Board version:R01
DSL uptime:0 days,00 Hours00 Mins18 Secs
Data rate:12.81 Mbps / 59.723 Mbps
Maximum data rate:12.810 Mbps / 60.858 Mbps
Noise margin:6.2 / 3.3
Line attenuation:9.1 / 17.8
Signal attenuation:9.1 / 22.7
VLAN id:101
Data sent / received:0.1 MB Uploaded  / 0.6 MB Downloaded
BT Wi-fi:Activated
Firewall:On
Software variant:-
Message 7 of 7
Speeds seem to be ok this morning, I've checked the event log for around the time the issues started and this is what was there:
17:32:23, 11 Dec. PPP: LCP up
17:32:23, 11 Dec. PPP LCP Receive Configuration ACK
17:32:23, 11 Dec. PPP LCP Send Configuration ACK
17:32:23, 11 Dec. PPP LCP Receive Configuration Request
17:32:23, 11 Dec. PPP LCP Send Configuration Request
17:32:23, 11 Dec. PPP: Received PADS
17:32:23, 11 Dec. PPP: Sending PAD
17:32:23, 11 Dec. PPP: Received PADO
17:32:23, 11 Dec. PPP: Sending PADI
17:32:18, 11 Dec. PPP: Sending PADI
17:32:13, 11 Dec. PPP: Sending PADI
17:32:08, 11 Dec. PPP: Sending PADI
17:32:05, 11 Dec. DSL Link Up: Down Rate=18367kbps, Up Rate=9105kbps; SNR Margin Down=3.4dB, Up=6.1dB
17:32:03, 11 Dec. PPP: Sending PADI
17:31:58, 11 Dec. PPP: Starting PPP daemon
17:31:57, 11 Dec. WAN Auto-sensing detected port DSL WAN
17:31:38, 11 Dec. SIP WAN DOWN
17:31:36, 11 Dec. admin timeout from 192.168.1.224
17:31:34, 11 Dec. SIP WAN DOWN
17:31:34, 11 Dec. WAN Sensing Auto sensing Complete, interface selected
17:31:34, 11 Dec. WAN Sensing Auto sensing Running
17:31:32, 11 Dec. WAN Sensing Auto sensing Complete, interface selected
17:31:32, 11 Dec. WAN Sensing Auto sensing Running
17:31:32, 11 Dec. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
17:31:31, 11 Dec. PPP LCP Send Termination Request (User request)
17:31:31, 11 Dec. PPP: IPCP down
17:31:31, 11 Dec. PPP: LCP down
17:31:30, 11 Dec. DSL Link Down: duration was 746991 seconds
I'm assuming that whatever that is, is what caused the slow speeds. Is it something I should be worried about? is the hub failing?
Many thanks for all your help imjolly
