Message 11 of 29
Re: Replacement batteries
It's not the easiest but that guide above makes it possible,
Message 12 of 29
Thanks for your reply, yes that is the diagram shown in the manual but I still don't understand how to make it open. Is there something I am missing.
Did you manage to get it opened by simply pressing / pulling the top apart like the manual shows. Or did you have to use a particular technique and if so could you describe it in detail please. Thanks for all your assistance everyone.
Message 13 of 29
This may be better:
Those 5 vertical channels (not seen in the guide picture) are where you need to push/pry and it'll easily release.
I've tested 2 units that I've alredy opened and they open easy but  I tried a new one just now and a little bit of force is needed -it's like a button motion on those 5 channels.
The BT instructions are very good once you realise you need to push in the 'button' and pry just like above ie it peels open.
Message 14 of 29
@FTT wrote:
This may be better:
I have the advance Alexa DV phone but there is no way I can get the 2 halves separated as you describe
Message 15 of 29
Ahhh that is the answer, that worked perfectly. !!!!
I think they should revise the manual to include what you say as it would be more helpful imho.
Thanks a million for your help everyone. 🙂
Message 16 of 29
I should maybe have mentioned I actually got my wife to open it, she has slim fingers and was able to use her nail to press on the 5 channels as you advised. 🙂
Message 17 of 29
@FTT
eventually managed as you described to split front and back😀
Message 18 of 29
Glad you managed it too. 🙂
Message 19 of 29
Glad you guys got sorted I'm especially happy to help the Very Reverend I.M. Jolly I grew up with his joyful and fulfilling homilies every New Year, it made me the person I am today.
Message 20 of 29
I always looked forward to the shows on Hogmanay  I have a few of the shows on video and it is great looking back
