Message 11 of 12
Re: Request for interleaving to be turned back on please.
engineer appears to have fixed your connection problem and hopefully line will now be stable.  your stats look good now with noise margin about normal 6db.  if your connection does start to drop then the DLM will automatically change latency to interleaved so just leave connection alone just now
Message 12 of 12
Ok thank you.
