Anonymous
Not applicable
Message 1 of 13
Resolution of Streams to a BT Box
Is the standard offering still fuzzy-vision?
12 REPLIES 12
Message 2 of 13
Re: Resolution of Streams to a BT Box
 I presume you are asking if there were any changes to the info supplied in your earlier thread
https://community.bt.com/t5/BT-Sport-on-TV-Online-player-or/What-Resolution-is-the-App/m-p/2114155#M...
Anonymous
Not applicable
Message 3 of 13
The you'd presume wrong, as you would know if you read the title of the two threads. 🙄
Message 4 of 13
Wow! Why the need to use the words "fuzzy vision"? FWIW the streams are perfectly watchable in standard definition
Message 5 of 13
The standard offering on the BT TV boxes hasn't changed - though I would argue that it's never been fuzzy vision. It's standard SD (576i) on the standard channels, full HD (1080i) on the HD channels, and 4k (2160p I believe) on the Ultimate channel.
Anonymous
Not applicable
Message 6 of 13
Because the last time I had it, "fuzzy-vision" was exactly what it was. You had to pay an extra sub for HD, hence the question.
Message 7 of 13
HD is still usually an extra cost, same as elaewhere as it doesn't appear to be fully standard in the UK
Anonymous
Not applicable
Message 8 of 13
576 was awful on the 42" I had at the time, on the 55" I have now it would be unwatchable. But thanks for confirming, I won't waste money ordering it.
Anonymous
Not applicable
Message 9 of 13
@garybs29wrote:
HD is still usually an extra cost, same as elsewhere as it doesn't appear to be fully standard in the UK
Thanks, shame BT aren't more honest about it. Although NowTV's standard offering is 720, which is at least acceptable.
Message 10 of 13
If you want HD quality, I'm afraid you need to pay for it @Anonymous
