Message 1 of 2
Roaming outside UK for several months
Is it possible to have with BT mobile  roaming when living outside the UK for more than three months?Is there any limit of being outside the Uk? Eg after three months outside the UK some companies terminate the roaming.
thanks
1 REPLY 1
Message 2 of 2
Re: Roaming outside UK for several months
Roam Like Home is only available if you live or are usually based in the UK and you mainly use your BT Mobile in the UK. If we think that over a period of at least 4 months you’ve been living or mainly using your BT Mobile in a Roam Like Home country, we may ask you to explain the reasons for this and you might need to pay a surcharge. You can find out more about the surcharge in our tariff guide
