Message 1 of 9
Router - Cable - Length
Does anyone know what is the max length of ethernet cable I can run from my BT router to another device?  Trying to get internet int my garage and Wifi wont reach.
8 REPLIES 8
Message 2 of 9
Re: Router - Cable - Length
100m
Message 3 of 9
Thanks imjolly - have you tested this?
Message 4 of 9
Its the standard length restriction for Ethernet Cat 5E and above cable.
Message 5 of 9
seriously🤔
Message 6 of 9
Lol - sorry, please don't be offended 😀. I had googled the max length for Cat 5 and found it was 100m, however , I am more concerned that a consumer grade router may not have the signal strength required to send a signal that far.
Thanks for your help!
Message 7 of 9
Also - sorry, do I need a cross over cable or straight through?
Message 8 of 9
the limitation is more to do with propagation time of the signal rather than power limitations.
Message 9 of 9
Doesn't matter these days, Ethernet devices are virtually all auto sensing now.
