Message 1 of 4
Router reset button
Hi does pressing the reset button mean I half to connect my devices to the internet again
3 REPLIES 3
Message 2 of 4
Re: Router reset button
If it is a factory reset and you have previously changed the wireless password the password will be restored to the factory setting and you will need to reconnect your devices with the correct password.
No if you have not changed the password or if all you are doing is a "soft" reset, which is effectively just turning the router off and on.  Your devices should just re-connect without you doing anything.
Message 3 of 4
Ok I have never changed the password or name so will they stay connected
Message 4 of 4
As per my previous post!
