Message 1 of 5
SANNCE security cameras - unable to view away from home
Hi looking for some help please.  Have just installed security cameras, can view through wi-fi at home but am unable to view when I am away from home through 4G.
Some months ago I had a indoor camera (to watch my dogs) that I’d had awhile suddenly stopped working (the same as above), I just thought it had broken so disconnected it but am now wondering if it was the same problem?
My son has had a go with it but to no avail - sos
4 REPLIES 4
Message 2 of 5
Re: SANNCE security cameras - unable to view away from home
@Sonick
Which BT Home Hub are you using?
Message 3 of 5
I have BT Hub 6A, can now add that have tried another router (non BT) & can view remotely
Message 4 of 5
The BT Home Hubs can cause issues with opening ports, so a third party router seems your best option in this case.
Message 5 of 5
I have exactly the same issue. Is it AT ALL possible to set my Smarthub 6 up so that I can view my CCTV remotely or is it not even worth trying?
